9 Pages«<56789>
#61 Posted : Wednesday, June 9, 2010 11:22:42 PM(UTC)
Check the timer for continuity between the BK and R terminals while the timer is in timed dry position.
lilteddyp
#62 Posted : Wednesday, June 9, 2010 11:23:48 PM(UTC)
lilteddyp
Plugged in, unplugged, running?
lilteddyp
#63 Posted : Wednesday, June 9, 2010 11:28:55 PM(UTC)
lilteddyp
unplugged, BK to R had continuity
#64 Posted : Wednesday, June 9, 2010 11:58:12 PM(UTC)
Remove the wires from the heating element (one at a time) and measure the voltage between this wire and the ground while the dryer is on.
lilteddyp
#65 Posted : Thursday, June 10, 2010 12:03:17 AM(UTC)
lilteddyp
one plugged in and one unplugged at a time, both sides seeing ~115
#66 Posted : Thursday, June 10, 2010 1:13:46 PM(UTC)
Looks like there is something wrong with the heating element. Check the resistance on each side of the heating element to the ground (both wires are unplugged). If the reading is not an infinite, replace the heating element.
lilteddyp
#67 Posted : Thursday, June 10, 2010 1:19:29 PM(UTC)
lilteddyp
No continuity (no change in meter, stays at a 1 at rest) when checking each side of element to ground, both sides of element unplugged, dryer plugged in to wall
#68 Posted : Thursday, June 10, 2010 2:45:02 PM(UTC)
What is the AC voltage scale on your meter?
lilteddyp
#69 Posted : Thursday, June 10, 2010 2:50:25 PM(UTC)
lilteddyp
200 option and 600 option. Im trying to upload a pic but photobucket is having an issue right now it appears
#70 Posted : Thursday, June 10, 2010 4:15:57 PM(UTC)
Set it on 600 VAC. Disconnect any one wire from the heating element and measure the voltage between this wire and the terminal where it was connected, and between this wire and the other wire still connected to the heating element. Post the results.
Guest (13)
No dryer heat (Dryer Repair)
by adamson 8/9/2009 3:11:05 PM(UTC)
No Dryer Heat/No shut of in auto cycle (Dryer Repair)
by fred2117 4/30/2009 2:09:57 AM(UTC)
No Dryer Heat (Dryer Repair)
by jackd3 10/6/2007 5:06:10 AM(UTC)
9 Pages«<56789>
