Sometimes the washer drains and sometimes you have to run spin cycle a second time to get it to drain. When it does finally drain, clothes are still very wet and sometimes there are still suds in the bottom of the tub. There are no clogged drain hoses and I've already replaced the pump and belt. My next try is thrust washer. Does this sound right or could it be something else. One more thing, last night on delicate cycle it did not agitate during rinse cycle. Is this correct? Thanks for any help.
thrust washer/bearing replaced. problem still exists!
Try to switch to HE detergent and use as little detergent as possible. Suds can cause such problem.
