Mark Carpender
#1 Posted : Monday, June 7, 2010 8:06:47 AM(UTC)
Mark Carpender
I bought a soap dispenser assembly from you for my dishwasher and found the part #WPL 8193920 looks the same on the outside but has a extra wire for a rinse aid sensor on the inside. (from what I see online the part is called out as a rinse aid sensor) Do you have the correct part for this dishwasher?
#2 Posted : Tuesday, June 8, 2010 1:32:46 AM(UTC)
Note: I do not work for AppliancePartsPros.
I searched both the model number and the manufacturer's part number and both came up with the same part.
So I would say that you have the correct item.
It is probably a universal dispenser and will run on units with and without the rinse aid sensing.
Fact is even if your unit had rinse aid sensing I would not hook up the sensor as they are more trouble than they are worth.
Mark Carpender
#3 Posted : Tuesday, June 8, 2010 7:37:06 AM(UTC)
Mark Carpender
Dear Sir, thanks for your help. I hoped this was the case, I was looking for somebody to confirm this. Thanks again
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
