2 Pages<12
ripleys
#11 Posted : Tuesday, December 4, 2007 6:49:21 PM(UTC)
ripleys
Part # for control board is 2252195 subs to 8201672. Hope that helps and good luck.
mch28
#12 Posted : Tuesday, December 4, 2007 6:55:14 PM(UTC)
mch28
Thanks for the p/n. $146
In the mean time, anyone familiar with the diagnostics. The water filter and power button for 3 sec's aren't doing it.
mch28
#13 Posted : Wednesday, December 5, 2007 6:06:24 PM(UTC)
mch28
Can someone please post the service guide on this model? I want to turn on the defrost circuit to make some tests.
JonnyMike
#14 Posted : Monday, May 26, 2008 11:38:27 PM(UTC)
JonnyMike
Originally Posted by: mch28 Go to Quoted Post
My refrigerator won't go into defrost mode. I have replaced the bi-metal thermostat with no luck. The evaporator freezes up solid after about 2 months and won't allow the air to flow through it to cool the fridge side. The freezer is fine. I don't have any guide for entering diagnostics. The heater ohms out fine. How can I manually defrost this unit? and What should I try next? There doesn't seem to be a defrost timer. I don't want to throw a $150 main PWB in to find out it didn't fix it.
Hey mch28,
Did you ever figure out what was wrong with your KitchenAid? I've got the same model (2-1/2 years old) and same problem. I also have the diagnostics sheet you were looking for. I ran the diagnostics and everything checked out. This has me somewhat puzzled but I'm still hoping it's the bi-metal (cheap) and not the control assly. (expensive). I'm thinking that my bi-metal might be stuck closed. After reading the diagnostics sheet, it sounds like this could throw off the electronic defrost cycle. The problem first occurred about a month ago when I noticed the refrig. side getting too warm. The freezer was OK but there was frost on the back wall. We have alot of power outages where I live so I figured the electronics might just need to be reset. After turning it off and unplugging the power cord, I powered it back up and the defrost cycle worked fine (until now). Anyway, if you succeeded in getting yours fixed and can share that info, I'd greatly appreciate it.
#15 Posted : Tuesday, May 27, 2008 1:04:59 AM(UTC)
Before replacing the control board, go to www.applianceaid.com There will be two different manual defrost procedures there, try both. Post results.
JonnyMike
#16 Posted : Tuesday, May 27, 2008 8:31:07 AM(UTC)
JonnyMike
The only manual defrost procedures I found on applianceaid.com were for units with a mechanical defrost timer. My unit is electronic. The diagnostics instruction sheet does have a procedure for checking the defrost heater/bi-metal, which checked out ok. Since there's nothing in the literature about a traditional defrost timer, I'm assuming it's built into the electronic control board. Please let me know if I missed something. Thanks richappy.
#17 Posted : Wednesday, May 28, 2008 2:38:31 AM(UTC)
In applianceaid. com, click on refrigerator repair, "then New adaptive defrost info"
JonnyMike
#18 Posted : Tuesday, June 3, 2008 10:46:57 PM(UTC)
JonnyMike
Thanks richappy, I found it. In the meantime, I went and bought a defrost bi-metal. Before installing it, however, I took everything out of the freezer side, removed back panel, defrosted evaporator with a hair dryer, reassembled, then powered the unit up. As expected, everything worked. Refrig. side returned to normal temp. (appx. 35 F.). I decided to just observe it for a few days and appx. 30 hours later, discovered that the unit was going through a normal defrost cycle. This suggested that the bi-metal and/or control board might not be defective after all. My questions now are as follows:
1.) Is it possible for the bi-metal to have stuck open, then snapped back closed after the hair dryer session?
2.) How often does the defrost cycle operate?
#19 Posted : Wednesday, June 4, 2008 1:07:48 AM(UTC)
Most probable failed item is the defrost thermostat, just replace it. They often fail intermitently.
2 Pages<12
