2 Pages12>
krupp
#1 Posted : Monday, June 7, 2010 7:17:34 AM(UTC)
krupp
Fridgidaire Freezer runs, makes noise at least, but isn't cooling. It is an upright, "commercial grade" unit which is about 5 years old. Contents have started to thaw. Walls of box on the outside are very warm to the touch. Freezer is in the garage which is dusty.
Suggestions on where to start? Fan, dirty coils, etc?
I am a fairly capable person with tools who can repair things, but I have no experience with Freezers.
Thank you.
#2 Posted : Monday, June 7, 2010 7:28:50 AM(UTC)
A model number may help others help you.
First clean the condenser coils under the unit.
Check that the condenser fan is running, if it has one.
Check that the compressor is running should be warm/hot and usually you can feel it vibrating.
Check that the evaporator coil fan is running in the freezer, if it has one.
Check the evaporator coils in the freezer, if the unit has them.
If heavily iced/frosted over you may have a defrost problem.
If patchy or they just have frost where the freon enters them you may be low on freon.
Here is a good link on fridge repair mush of the info also applies to freezers depending on the type.
http://www.applianceaid.com/frig.html
krupp
#3 Posted : Monday, June 7, 2010 8:41:05 AM(UTC)
krupp
It is a Fridgidaire Model LFFU1765DW3.
An update... Underneath the unit appears to be just the compressor unit (black sphere). No evidence of any leakage or anything wrong. So, I removed the cover on the inside to expose the condensor, fan and thermostat on the back wall of the box. I plugged it in, operated the thermostat and things are appearing to run (fan, compressor, etc).
The unit has been sitting open overnight, so I don't know what condition the condensor was in, since the freezer has thawed for about 12 hours now. Contents have been transferred to another freezer.
Thanks.
#4 Posted : Monday, June 7, 2010 9:01:35 AM(UTC)
Here is the tech sheet for it
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/216857700.pdf
I would put in an ice cube tray with water or a thermometer and plug it in.
Let it run for at least 8 hours and see what happens.
If it freezes the water or gets down to around 0 degrees F then odds are you had a defrost problem.
krupp
#5 Posted : Monday, June 7, 2010 9:40:17 AM(UTC)
krupp
Thanks.
I'll put some water in the unit and wait until tonight.
Also, right away, I noticed frost building up on the evaporator inside.
Is this normal?
#6 Posted : Monday, June 7, 2010 11:33:07 AM(UTC)
Yes, since the door was open the water vapor in the air will condense on the evaporator coils.
Actually it is a very good thing as it indicates the unit/compressor is running OK so it should not be that expensive to repair.
krupp
#7 Posted : Monday, June 7, 2010 1:34:14 PM(UTC)
krupp
denman,
Thank you for your help with this.
Well, I placed a thermometer and small container of water inside the freezer, on the top rack, about 4 hours ago. The water is frozen solid and the thermometer reads about -4C. Like you said, since the unit is freezing, I guess this means that I have an auto defrost problem? The evaporator is definitely becoming covered with frost. I suppose what happens is that it could become heavily covered, and not go through an auto defrost cycle, and eventually not work properly with the fan.
So, now do I check the defrost timer, t-stat, element, etc?
#8 Posted : Monday, June 7, 2010 3:23:48 PM(UTC)
Replacement parts for FRIGIDAIRE LFFU1765DW3 Frigidaire/freezer | AppliancePartsPros.com
Take a look at Item 23 in Section 3.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
krupp
#9 Posted : Monday, June 7, 2010 6:10:31 PM(UTC)
krupp
denman,
I manually forced a defrost cycle by turning the timer knob until it clicked and the compressor and fan turned off.
I walked around to feel the defrost heating element and within a couple of seconds I could tell it was hot by just tapping on it with my fingers.
So, this means that it is not closing a contact automatically and starting the defrost cycle? This means I need a new defrost timer?
Thanks again.
#10 Posted : Tuesday, June 8, 2010 1:05:01 AM(UTC)
[COLOR="Blue"]So, this means that it is not closing a contact automatically and starting the defrost cycle? This means I need a new defrost timer?[/COLOR]
Yes
The defrost heater and thermostat check out OK so the timer is the only thing left.
Guest (4)
2 Pages12>
