Hello all,
Problem started with intermittent flickering and shutting off of LEDs and ice dispenser on front panel. Eventually the panel would no longer illuminate nor did the water/ice dispenser work at all. I replaced the front panel assembly WR55X10859 and had the same problem. Put meter on wires and was only getting ~8v. Did some more research to find out this was symptom of motherboard failure so replaced motherboard as well with the updated model. No help and now have 0v to front panel. Fridge and freezer are staying at correct temps and no other problems. What now?:confused:
Just after posting this I checked actual wiring. Followed the wiring up underneath and found a crimped wire (prob from factory) that I guess finally gave out. Spliced that and all is well. Never think to check the obvious things first... :D
How are you getting under your fridge to see these wires? I am having the same issues
