Bob1394
#1 Posted : Friday, June 4, 2010 2:56:27 AM(UTC)
Bob1394
Hello,
No water is going into the dishwasher when i turn it on. there is water going thru the pipes, I replaced the inlet valve and still nothing. what could it be?
thank you
#2 Posted : Friday, June 4, 2010 3:59:03 AM(UTC)
Check the overflow switch.
Left hand side behind the kick plate.
May even be that the float is stuck in the up position.
Bob1394
#3 Posted : Friday, June 4, 2010 2:55:58 PM(UTC)
Bob1394
Hi Redman,
what exatly am i looking for. what does the switch look like.
Bob1394
#4 Posted : Friday, June 4, 2010 3:04:13 PM(UTC)
Bob1394
I dont see it on the diswasher and i dont see it in the parts diagram.
#5 Posted : Friday, June 4, 2010 3:44:36 PM(UTC)
Part number: AP3044159
The float assembly sticks up from the floor on the tub.
I think on your unit it is on the left hand side front inside the unit.
The switch is directly under the float assembly under the tub behind the kick plate.
The way it works is if the unit overfills, the float floats. It has a shaft going down to a switch. The switch de-activates killing power to the water valve.
