2 Pages<12
kayakcrzy
#11 Posted : Friday, June 4, 2010 3:12:42 AM(UTC)
kayakcrzy
Originally Posted by: sroloff Go to Quoted Post
The high T-stat? My understanding is if that if I jumped that the flame would never go out (which is what was happening) and what I meant when I said it was getting hot (smelling) when turned I turned it off. Why wouldn't gas ignite when I jumped the flame sensor? On the thermostats are we maybe talking about Cycling Thermostats #14 & #15? Not even sure where those are mounted just saw them in the parts list? Where are they and how do I know which one or even the problem? I need to order rollers and other stuff just want to get it right the first time when I place the order. Thanks.
OK, I am confused. If you put everything back to the way it should be, The ignitor will come on, or not. Like I said before, if the gas comes out, when you jump out the thermostat, that is the problem. Whatever part you jump out, and makes it work, is the problem.
sroloff
#12 Posted : Wednesday, June 16, 2010 5:37:07 PM(UTC)
sroloff
H-Stat was the problem. Replaced and all works like new again. Thanks.
kayakcrzy
#13 Posted : Thursday, June 17, 2010 3:21:06 AM(UTC)
kayakcrzy
Good Job!!!! Tom ApplianceEducator.com
Triskellion
#14 Posted : Saturday, July 24, 2010 12:07:05 PM(UTC)
Triskellion
Originally Posted by: kayakcrzy Go to Quoted Post
Great Job!!! That is the way to save the cash. Tom ApplianceEducator.com
This advice worked for me, too. Very cool -- $20 for the dual-coil kit, 15 minutes under the dryer, and we're back in business. Thanks so much to everyone for the advice.
Dsully
#15 Posted : Tuesday, August 23, 2011 5:00:42 AM(UTC)
Dsully
Where do you get the duel coil kit? There are three coils listed under parts...if the flame is going out after a short 3 second burst...do all three coils need to be replaced? Thanks!
2 Pages<12
