I'm have some issues with my ice maker. About 2 years ago the led begain to flash two quick flashes the a pause the repeat. The ice maker was working fine, but it was a little slow. A couple of days ago the ice maker refused to dump the ice that was currently in the mold, I removed the ice maker and used some water to remove the ice. After I reinstalled the ice maker it is doing nothing, the led is still flashing, but it wont fill with water. Any ideas/suggestions?
Joe Lagle
Hi Joe, Open the freezer door. Close the flapper door on the left side and watch the LED on the right side. If it's blinking, most likely the problem is a bad optic PC boards. - The PC boards kit Part number: AP3137510
