teacher95864
#1 Posted : Saturday, May 24, 2008 12:04:57 PM(UTC)
teacher95864
As I was pulling the oven out to get behind it the door came off. now i cant get the hinges to cooperate in getting it back on. the srpings are still strong because i cant keep the at the 1st stop long enough to hook it back on. what do i do to get this door back on?:confused:
jeffalex2
#2 Posted : Saturday, May 24, 2008 6:08:29 PM(UTC)
jeffalex2
...or a small board...keep your fingers away from the spring hinges. Use a large pair of plyers/channel locks to pry the hinges down far enough to get a broom stick or board stuck in the hinges. Do one at a time. Once the hinges are stuck open far enough, slide the door back on. Then, use the door to open the hinges up and take out the stick.;)
