Sharon Bailey
#1 Posted : Tuesday, June 1, 2010 9:51:54 AM(UTC)
Sharon Bailey
When door was opened, heard a loud snap, and all the tension is gone from the hinge/spring. HELP.
#2 Posted : Wednesday, June 2, 2010 2:47:02 AM(UTC)
Replacement parts for KUDS01FK models | AppliancePartsPros.com
Sounds like a cable may have snapped, see Item 24 in Section 7.
You will probably have to pull the unit out from un der the cabinet to get at them.
The following may help
http://appliancejunk.com/forums/index.php?topic=2123.0
http://appliancejunk.com/forums/index.php?topic=1540.0
Sharon Bailey
#3 Posted : Monday, June 7, 2010 8:04:49 AM(UTC)
Sharon Bailey
Originally Posted by: denman Go to Quoted Post
http://appliancejunk.com...s/index.php?topic=2123.0
http://appliancejunk.com...s/index.php?topic=1540.0
Thanks much--that worked perfectly--part was about $14--my daughter just had the same thing happen to her identical make and model--she hired it done--over $200. Yikes and ka-ching. Thank you again.
