OK I was hoping I wouldn't have to visit this forum for a while but no such luck. The problem's with my daughter's GE freezer on bottom model # PFS22SISBSS. The freezer is not working as well with the summer weather. Thermostat is set to 0 degrees F, but temp only goes down to 22 degrees. The icemaker doesn't work either, although I don't know if its related. Is this is common problem with this model? Any hints? Thanks, Dave
