vince3816
#1 Posted : Tuesday, June 1, 2010 5:35:27 AM(UTC)
vince3816
Gas range works, broiler works, oven stopped working in the middle of baking. Glow plug gets hot, but oven will not light. No error codes and I turned off the power to reset the electronic with no success. Any idea what I should try next?
PAUL DA PLUMBER
#2 Posted : Tuesday, June 1, 2010 11:37:01 PM(UTC)
PAUL DA PLUMBER
Im Having The Same Problem. Did U Fix The Problem???
vince3816
#3 Posted : Wednesday, June 2, 2010 5:35:21 AM(UTC)
vince3816
Paul, I called my local parts distributor for advice. After checking both glow plugs for the broiler and oven, both bright orange. I attempted to light the over the regular way with the key pad while tapping on the gas valve and regulator. The oven lit. I ordered a new gas valve and regulator, about 140.00 dollars. It will come in this Friday. We shall see if this fixes the problem.
Kitchen Aid Oven will not light (Oven Repair (including Ranges and Cooktops))
by JAB4043 4/25/2010 7:50:41 AM(UTC)
