2 Pages12>
VIN
#1 Posted : Saturday, September 29, 2007 8:38:24 AM(UTC)
VIN
Hello, I have a whirlpool oven and the bake element and broil element do not work or just stopped workimg. The elements ohm out at 25.1 so I am assuming that they are good. I am wondering if it could be the sensor but how can i check the sensor, or does anyone know what my problem might be
:confused:
Admin / APP Team
#2 Posted : Saturday, September 29, 2007 9:56:09 AM(UTC)
Admin / APP Team
Rank: Administration
Hi Vin,
First, check the circuit breakers. There are two breakers controlling your oven, make sure neither's tripped. Post back...
VIN
#3 Posted : Saturday, September 29, 2007 10:05:18 AM(UTC)
VIN
Are those breakers located inside the oven? Thanks for your response!
Admin / APP Team
#4 Posted : Saturday, September 29, 2007 10:07:47 AM(UTC)
Admin / APP Team
No, the house circuit breaker box. There should be two for the oven, side by side. Usually 40 amp (and 110 volt) each. It's common to have one of them tripped - this will still power up the control but won't be enough to power the elements.
VIN
#5 Posted : Saturday, September 29, 2007 10:16:01 AM(UTC)
VIN
The breakers in my box are connected with a bar across the two so if onr trips the other will also trip unless only one can go bad. is it possible to take the circuit brkr apart to test it or should i just purchase a new one?
Admin / APP Team
#6 Posted : Saturday, September 29, 2007 10:42:10 AM(UTC)
Admin / APP Team
I would reset both breakers. Turn them off, wait about 30 seconds, then turn them back on. Don't take anything apart in there.
If the problem is still there, then we need to take a look inside the oven. This will involve using a voltmeter. Do you have one and know how to use it?... I see one fuse in this oven. It's not clear, but the fuse is probably part of the main wiring harness. May be as simple as a bad fuse.
- Wiring diagram for your oven
VIN
#7 Posted : Sunday, September 30, 2007 3:46:53 AM(UTC)
VIN
I have turned those breakers off a couple of times now. I don't think its the breaker.
Let me make sure you have all the info. my bake and broil elements are not working. The cooktop elements are woking fine with the exception of the keep warm element when I was going through the buttons on the control panel to see if everything else was working I noticed that when I turned on the keep warm element the light on the switch did not light up and does not get warm. When I turn on the bake (broil) the control panel goes through its motion of telling you the temp and going into the preheat mode but get no heat. When you put it into convection cook the fan works but again no heat.
Yes I have a voltmeter and know how to use it. Is there a fusable link or an actual fuse because I have been inside the back already and did not see any kind of fuse on any of the wires or leads leading to the control panel, but that does not mean that I could have missed it if it was hidden. In any case I will be waiting for your reply. Thanks for your attention in this matter!
#8 Posted : Friday, October 5, 2007 3:56:21 PM(UTC)
Hi VIN
The first thing I would check in such situation is if you have 120V (L2) coming to the control board. As I can see on the wiring diagram it should be a single red wire plugged into the control board.
Remove this wire from the control board and check it for a 120V (between the red wire and the ground).
If there is no 120V then the problem is a fusible link in the wire harness. Locate were is it and replace it. You can buy it in any electronic store.
If there is 120V then the problem is a bad control board which has to be replaced.
- The part number for the new control board (white) AP3083740
- The part number for the new control board (black) AP3083741
- Here are the break down diagrams for the Whirlpool range Model GR450LXHQ2
Good luck.
VIN
#9 Posted : Saturday, November 3, 2007 3:27:48 AM(UTC)
VIN
:) The bake and broil are working fine now!!! I want to thank all the people invovled persuing my oven's ailment. I am very happy ;) with the quick response to my problem from everyone and the excellent knowledge in your fields.
It is good to know that there is a place like this were you can find the answers you are looking for without calling an expensive service rep. that might even try to sell you something you don't need. :D
Mahi04
#10 Posted : Thursday, May 22, 2008 6:37:16 PM(UTC)
Mahi04
I have the same problem with my Oven. The fan works, warmer does not, and the oven does not heat up. I tried finding the fuse, but could not locate. I really hope it was not replacing the control panel. I put a voltmeter on the red wire coming from the control panel and there was no voltage reading.
Is it safe? Can I use electric oven again after POP noise and breaker tripped? (Oven Repair (including Ranges and Cooktops))
by Guest 3/2/2024 5:41:59 AM(UTC)
KitchenAid builtin electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2024 5:07:18 PM(UTC)
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
Whirlpool Electric Oven Convect Broil (Oven Repair (including Ranges and Cooktops))
by Guest 8/12/2022 8:27:28 AM(UTC)
GE Electric Oven - Won't stay on (Oven Repair (including Ranges and Cooktops))
by tstwingirls@yahoo.com 2/23/2022 3:51:15 PM(UTC)
Frigidaire electric oven model number PLEF489CCF (Oven Repair (including Ranges and Cooktops))
by Guest 7/25/2021 4:06:10 AM(UTC)
LG LSE3092 Electric Oven (Oven Repair (including Ranges and Cooktops))
by cycle70 4/10/2021 11:11:00 AM(UTC)
GE Profile electric oven will not turn on (Oven Repair (including Ranges and Cooktops))
by toddlamp 3/31/2021 7:03:39 PM(UTC)
ge tru-temp electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/17/2021 4:26:18 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
ZLINE RA36 ELECTRIC OVEN (Oven Repair (including Ranges and Cooktops))
by AndyGray 1/21/2021 5:13:45 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
Electric oven panel issue? (Oven Repair (including Ranges and Cooktops))
by nhreprops 11/23/2019 10:59:26 AM(UTC)
Can I use the electric oven without the broiler heating element? (Oven Repair (including Ranges and Cooktops))
by Al Thumbs 3/16/2019 10:53:19 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
2 Pages12>
