jxg8171
#1 Posted : Thursday, May 22, 2008 7:04:08 AM(UTC)
jxg8171
My dryer has been performing fine until a few days ago when I realised that the heat had stopped working. I need to be able to find out which part I need to replace therefore I need a starting point.
Where do I open the machine up and should I be able to spot which part needs replacing.... I think there are three possiblities
a. the coil
b. burnt wire connector
c. thermostat
Please help
kayakcrzy
#2 Posted : Sunday, May 25, 2008 5:04:16 AM(UTC)
kayakcrzy
Actually, just take off the bottom panel, and look all the way in the back on the bottom left side, and there will be the element housing. There is 2 screws holding it in, and there it is. If you need me you can reach me at my web site at ApplianceEducator.com Tom
SublimeMasterJW
#3 Posted : Sunday, May 25, 2008 8:57:46 AM(UTC)
SublimeMasterJW
start herethreadbelt2.jpgremove the front after wards and get the drum out.
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#4 Posted : Sunday, May 25, 2008 9:01:45 AM(UTC)
SublimeMasterJW
On bottom in rear, to the left, is the heater assembly. Just check it for broken wires or put a meter on it. Anything without continuity is the problem. When checking parts remove one of the wires so as not to get a backfeed(false reading)I am assuming you have the machine disconnected from power source.
Amana electric dryer - no heat (Dryer Repair)
by TimInOhio 10/15/2009 12:05:13 AM(UTC)
