Sharp R-1870 convect micro oven only runs for 59 seconds on miucrowave side and then shuts off, example if timer set for 2minutes micro will shut off at 1min 1 sec left can simply be restarted by pressing start again and it resumes where it left off. Any ideas? Bad board? which one? Thanks all help is appricated.
I had the same problem,it was the damper motor,i replaced it for about $25. with shipping.Fixed works like new.Thanks to this site.
