wklages7
#1 Posted : Wednesday, May 26, 2010 8:50:16 AM(UTC)
wklages7
I'm having iisues with my Kenmore Electric Dryer. It will sometimes start and run for 5-20 minutes but then just stops. At this time and other times, when I try to start it, it will give me an electric noise like the capacitor is not working. When it runs, I get heat. I will be checking on the motor to see if it is seezing up but my initial thought was the capacitor. Any and all suggestions are most appreciated.
#2 Posted : Wednesday, May 26, 2010 3:03:56 PM(UTC)
There are no motor capacitors used in dryers, so most likely the problem is a bad motor.
- The motor Part number: AP3094233
