cajan
#1 Posted : Tuesday, May 20, 2008 11:18:50 AM(UTC)
cajan
The dryer overheats and shuts off. I checked the venting but there is no blockage. Is there some switch that might need replaced? Any help would be appreciated.
#2 Posted : Tuesday, May 20, 2008 7:51:40 PM(UTC)
Were you able to restart it right away?
Did it make any noises?
cajan
#3 Posted : Tuesday, May 20, 2008 7:59:38 PM(UTC)
cajan
It had to cool down for a few minutes. No noises
#4 Posted : Wednesday, May 21, 2008 2:58:12 AM(UTC)
I would measure the exhaust temperature to see if it shuts off at more than say 160 degrees. If so, you probably have a bad cycling thermostat.
cajan
#5 Posted : Wednesday, May 21, 2008 4:12:26 PM(UTC)
cajan
I will try to change the thermostat, but I was told there was more than one. Do you know which one it might be or have a part number? Thanks for the help!
SublimeMasterJW
#6 Posted : Wednesday, May 21, 2008 5:12:50 PM(UTC)
SublimeMasterJW
Thermostat - Cycling (L155-25F)
P/N: 3387134
SublimeMasterJW
#7 Posted : Wednesday, May 21, 2008 5:16:26 PM(UTC)
SublimeMasterJW
spark module.jpg on the left is the vent and above that is the thermostat doing its thang registering the air which comes out of the drum.
SublimeMasterJW attached the following image(s):
Dryer too hot flips the thermal fuse (Dryer Repair)
by Maverick1 12/6/2017 6:29:07 AM(UTC)
Frigidaire Dryer Too Hot and doesn't stop on Auto (Dryer Repair)
by rgrandmaison5@gmail.com 11/16/2014 3:00:14 PM(UTC)
whirlpool dryer too hot (Dryer Repair)
by nurse_amy1@live.com 10/16/2014 1:02:40 PM(UTC)
by MWIDONNA 10/15/2014 4:51:36 PM(UTC)
Kenmore Dryer too hot (Dryer Repair)
by jsamp05 8/11/2013 12:11:50 PM(UTC)
Whirlpool gas dryer too hot (Dryer Repair)
by dorkfart 8/1/2013 6:56:43 AM(UTC)
dryer too hot (Washer Repair)
by ray4005 6/23/2012 10:19:59 AM(UTC)
dryer too hot on perm press cycle (Dryer Repair)
by jerrydc 6/20/2012 11:09:45 AM(UTC)
Dryer too hot and not cooling down (Dryer Repair)
by msbee03 6/13/2012 11:46:21 AM(UTC)
Whirlpool electric dryer too hot (Dryer Repair)
by Fixnitmyself 5/16/2012 12:36:00 PM(UTC)
GE dryer too hot (Dryer Repair)
by cap10chris 3/18/2012 4:22:45 PM(UTC)
Dryer too hot then quit (Dryer Repair)
by Jon Sims 1/16/2012 7:16:06 AM(UTC)
by indycraft 4/28/2011 12:09:53 PM(UTC)
dryer too hot? (Dryer Repair)
by jamiemad1 4/8/2011 12:30:54 PM(UTC)
by Alina0212 4/1/2011 11:07:07 AM(UTC)
