mechman32
#1 Posted : Monday, May 24, 2010 9:35:37 AM(UTC)
mechman32
I am trying to replace the tub hosing in this washer, I am trying to turn counterclock wise to remove it and it won't budge, have be applying pen oil to loosen it up , but no avail.
Am I turning the correct direction to remove hub.:confused:
The item I am referring to is under the transmission section on the parts list for this washer, item #7. My greatful thanks for any help in this matter.
#2 Posted : Monday, May 24, 2010 1:45:40 PM(UTC)
You have to have some special tools for this job. Hopefully the Service bulletin will help you.
mechman32
#3 Posted : Monday, May 24, 2010 7:36:00 PM(UTC)
mechman32
Thank you for the info. Is the tub hub usually very hard to turn? It acts like it is siezed up.
#4 Posted : Monday, May 24, 2010 9:32:10 PM(UTC)
It's very possible.
