gmick
#1 Posted : Monday, May 24, 2010 10:19:35 AM(UTC)
gmick
Just replace a broken icemaker (did not fill with water)
24 hour later the refrig/ freezer stopped cooling
The condensor is clicking and hot so I think it is a problem with the relay overload start capacitor (part 8201799)
Questions:
  • Any explanation how replacing the icemakee could lead to my problem?
  • The replacement part comes in pieces and looks different from the older unit (a 3n'a starter)......any recommendations regarding installation?
  • Is this worth repairing in an old Kenmore (assuming the condensor is still good)
  • Thanks gm
#2 Posted : Monday, May 24, 2010 2:24:17 PM(UTC)
The ice maker has nothing to do with it. There is no any connections between the ice maker and compressor.
The replacement start device kit comes with the installation instructions.
It depends on the condition of the unit and cost of repair.
- The start device kit Part number: AP3873993
gmick
#3 Posted : Monday, May 24, 2010 2:42:03 PM(UTC)
gmick
Gene thank you for your opinion.
The part you suggested does not list my specific model of kenmore whichis 10650564991 Do you think it will still do the job? many thanks, gm
#4 Posted : Monday, May 24, 2010 9:11:51 PM(UTC)
The part number I posted is the Appliance Parts Pros part number. It looks different but the part is absolutely the same. If you would like to confirm it, just type in the part number you have in the Search box.
