I just moved and after setting up the washer found it no longer completely drains, some water is left and the clothes are soaked. I have tried eeverything to get it to completely drain but nothing works, could something have happened during the move? It worked fine before. Would appreciate any help you can give me. Thanks
Thanks so much, we tilted machine and found the belts had become loose during the move, we tighted and viola....... washer now drains. Thanks so much
You are welcome. I'm glad you were able to fix it with no cost to you.
