AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer Drum Won't Turn, But Turns On & Heats Up
The dryer drum doesn't turn, but sounds like it's on.. and heats up inside. Is this a belt issue ? Where's a good place to find those? Thanks Worth replacing?
If the motor is running but the drum does not turn, then the problem is a broken belt. It's pretty simple repair and is definitely worth to fix. You can order the belt by clicking on the part number or the picture bellow. - The driving belt Part number: AP2946843
Here is the belt diagram: Gene. P.S. It is a good time to clean the dryer inside and check the drum support rollers and the idler pulley.
Hey, thanks for the info! I was able to find a belt locally, since I needed to get it done ASAP before my new renter moves in. Also, I found a great video on youtube showing how to do the whole thing. The internet is great! Cheers!
Dryer Repair
