danregan
#1 Posted : Sunday, May 18, 2008 2:37:08 PM(UTC)
danregan
I haven't been able to figure out how to keep my older GE washer (wwa7050b) from spilling water while filling. It seems to have a weird blue device whose job it is to spill water on the floor -- see the attached image. The fill valve attaches to this device with a hose, and another hose runs from this device to the washer tub to fill it with water.
But this thing is open to the air, with a hole in the side of it where water overflows onto the ground while the things fills.
At first I though, "Oh, ok. I guess this is the way they regulate the fill rate on this washer -- I guess I need to turn down the faucets that hook up to the fill valve until it stops leaking." But it never stops leaking, unless maybe I turn the water down to a tiiiiiiny trickle, which seems way too little water.
Can anyone explain this thing to me?
thank you!
-dan
danregan attached the following image(s):
#2 Posted : Monday, May 19, 2008 4:49:19 AM(UTC)
Need a better picture, but this is a inlet assembly which acts as an aerator. I would just use silicone cement and close the hole. Before doing this, confirm there is no pinched hose to cause turbulence.
