gakor
#1 Posted : Monday, May 17, 2010 8:25:28 PM(UTC)
gakor
Hello,
I have an RC20K-3AW Magic Chef Fridge (19 years old). It works fine, except the dividing wall at the front in between the fridge and freezer has been heating up a great deal. It now actually hurts when touched. Any idea what the problem may be? What part may need a replacement?
Thanks ahead,
G'day
Greg
UserPostedImage[URL="http://www.homerepairforum.com/forum/editpost.php?do=editpost&p=37559"][/URL]
#2 Posted : Tuesday, May 18, 2010 2:17:27 AM(UTC)
Replacement parts for RC20K-3AW models | AppliancePartsPros.com
Looks like you may be missing a digit after the K.
Often this is a problem with removing the heat from the condenser coils under the unit.
Clean the coils and the fan blade.
Looks like the coils are what is called a jelly roll type.
I do not know if you can do this but I remove the front kick plate and the rear cover. Then roll the unit to an open door and blow them clean with a compressor. Most of the dust ends up outside.
I also understand that a leaf blower works well.
If not possible a long brush and a vacuum can be used.
Removing the fan will make this a little easier.
Also check that the condenser fan is running correctly.
Some units have what is usually called an Econo switch (or something like that). If yours has this turn it off.
kayakcrzy
#3 Posted : Tuesday, May 18, 2010 3:58:30 AM(UTC)
kayakcrzy
Originally Posted by: gakor Go to Quoted Post
Hello,
Thanks ahead,
G'day
Greg
UserPostedImage[/URL]
If the center divider is hot, it is definetly an air movent problem. If the coil in the front is not dirty. Pull the refrigerator out, and take the bottom back panel off, and see if the condenser motor, which is next to the compressor is running. The blade could be blocked, and not turning, Or, the motor is bad,, or turning slow. Tom [url]www.applianceeducator.com/parts.htm
gakor
#4 Posted : Thursday, May 20, 2010 8:27:50 PM(UTC)
gakor
Thank you for the replies, denman and Tom. You gentlemen were absolutely right, and very helpful. The coil was packed with dust and dirt, and as Tom suspected, the motor was dead. Once again, thank you very much for your help. Much appreciated. G'day Greg
kayakcrzy
#5 Posted : Friday, May 21, 2010 3:08:15 AM(UTC)
kayakcrzy
Glad to help!! Tom ApplianceEducator.com
