peiboy
#1 Posted : Friday, May 16, 2008 6:12:55 PM(UTC)
peiboy
Hi
I have been trying to diagnose the issue that I just recently discovered with my Maytag Atlantis Washing Machine (Model # MAV7257AWW).
Everything appears to be working electrically - but the device will not spin or agitate.
I had the washer apart to see what could be wrong with it and here is what I observed:
The belt is on and in place - it seems ok.
The motor is loose, but I cannot seem to tighten it up, as it appears to be designed to move around (there are plastic guides that slide around and cannot be tightened)
The cam on the transmission bearing appears to be OK, but the dust cover was rubbing on the floor and had a hole worn in it. I took the assembly apart and it appears to be OK.
The drum is very difficult to turn manually - which concerns me, but I never took the time to feel it when it was "normal" so I cannot comment.
I have narrowed it down to 3 possible items
1 The Belt is shot
2 I need a thrust bearing kit
3 The Tranny is gone and I should make a planter out of the washer.
Does anybody have any suggestions for me as to how to narrow it down with out just replacing parts?
Thanks in advance
Jonathan
#2 Posted : Saturday, May 17, 2008 3:46:33 AM(UTC)
You probably have a blown lid switch, part # AP3159413
peiboy
#3 Posted : Saturday, May 17, 2008 4:53:14 AM(UTC)
peiboy
Sorry, forgot to mention - the lid switch is fine, I checked it for correct operation. The motor is running, and the belt is moving - as the system pumps the drum out, it just cannot transfer any energy to the transmission, or the transmission is not working
I need to figure out how to troubleshoot the transmission assembly, any ideas?
Jonathan
peiboy
#4 Posted : Saturday, May 17, 2008 6:54:24 AM(UTC)
peiboy
VICTORY IS MINE!
I was searching a bit more in depth on the web and I came across a post in another forum that talked to a stuck brake on this same model.
I got back underneath it and took the pulley assembly off and started to take the brake housing apart when I noticed the Warning label about the 200 lb spring that is compressed inside.
So I did not fully disassemble the brake housing, instead I loosened it up a bit, did a few gentle hits with the hammer to "persuade" it to move. I tighted the housing up, put the pully assembly back on. tried to spin it back and forth a few times and
"Bang"
The brake released, and the machine was back off and running!
I now have two questions:
Is brake siezure common on this washer?
If you need to take that housing apart with the spring installed is there a good way to do it without loosing an eye?
Thanks for your help
Jonathan
(going to go do laundry now)
carmine73
#5 Posted : Saturday, June 9, 2012 6:53:37 PM(UTC)
carmine73
Ok i had to register to reply to your thread but it was alll worth it you made my day.your ahahaaaa moment with the jambed brake was also my ahaaaaaaaa moment. your post was extremely helpfull. i did not need to do anything more than to open the front of my machine and love the top of the brake unit once of twice with a big dead blow mallet. i then turned the drum back and forth once or twice and VIOLA MY WASHER IS NOW SPINNING OUT AGAIN!!!! apparently this happens to more than just your maytag washer. I am so gratefull i found your post and i also am very happy you took the time to write up a reply and explain what your solution was. I just like you was warded off by the 200 pound spring warning label, and i didnt get as far as looking up a repair manual but with your help it was totally not necessary thanks a million times and have a freaking awesome weekend!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Carmine 73
#6 Posted : Sunday, June 10, 2012 12:47:54 AM(UTC)
For the record, if you need to pull out the brake housing, you can replace the brake housing screws one at a time with 10-24 - 1 1/2 inch screws, 1 inch longer than the existing ones. This will enable you to release pressure on the spring by symetrically loostening each one without the purchase of the expensive brake release tool!
jesus freak
#7 Posted : Sunday, March 31, 2013 7:50:49 PM(UTC)
jesus freak
Saw this thread and I am thinking I have the same problem. My washer won't agitate, but it will spin. I have taken the transmission cover off and everything looks in place. The bottom pulley will rotate only if I apply a lot of force ( for both directions). Do I need to beat on the brake too?
#8 Posted : Monday, April 1, 2013 12:31:27 AM(UTC)
Seems like your transmission is bad if it will not agitate.
jesus freak
#9 Posted : Monday, April 1, 2013 3:11:48 AM(UTC)
jesus freak
Ok. How do I educate myself on transmission issues? Do you know of any videos or troubleshooting procedures I could view?
Also, can you recommend a replacement/new model?
Thank you!
Guest (5)
