My range 1 yr 2 months old and gives a fault code of F10 when trying to use oven. It just past the 1 yr warranty
The "F10" error code means "Runaway Temperature". For more accurate advise we need the complete model number of the range.
Gene,
The complete model # is 790.9421240A and the fault code is F10 Sears won't send a repair man out unless it is Tuesday and someone needs to be here from 9 to 5 and with my schedule the range won't be fixed till Xmas next year! I would appreciate any help you can give me.
Thanks Les Roderfeld
