dsr4866
#1 Posted : Friday, May 16, 2008 8:56:53 AM(UTC)
dsr4866
The igniter on the back right side continues to spark after a flame . I assume the module is bad. Is there anything else I should look for?
David
#2 Posted : Friday, May 16, 2008 6:15:28 PM(UTC)
David,
The spark module is the last part I would think about.
The first thing I would do is make sure the igniter is clean from grease, not damaged and properly aligned. Then check if the burner is properly grounded.
Here are the break down diagrams for the Bosch cook top Model NHT722
