mahi42
#1 Posted : Thursday, May 15, 2008 1:14:04 PM(UTC)
mahi42
oven will not work , have replaced the control board $$$$ and oven will still not light . Everything else works , broiler , timers etc with the exception of bake and convection bake . Could it be the ignitor ??? Thanks
misterfixall
#2 Posted : Thursday, May 15, 2008 6:03:21 PM(UTC)
misterfixall
it may be ignitor, is it glowing? if so you are getting 110 volts. if not check for 11o volts at ignitor. check this first
mahi42
#3 Posted : Friday, May 16, 2008 6:16:05 AM(UTC)
mahi42
about 2 weeks ago it wouldn't light up . when I turned on oven you would hear it click but would not light up. Called a repairman and the morning he was coming it started working again.worked for a week and quit again. had repairman come out and he said it was the control board .I bought 1 for $240 from appl partspros. installed it and it still won't work.I know i can't return the control panel because i already installed it .Thats is why after reading this forum I was thinking it might be the glow bar. I should have found this forum before I bought parts. Too soon old ,too late smart LOL
thanks for your'e input and answers Larry
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 11/26/2022 8:40:21 AM(UTC)
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 10/16/2021 7:56:35 AM(UTC)
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
Belarus Guest 9/6/2021 9:36:45 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 3/18/2020 3:28:11 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
Belarus larrywick 10/18/2019 2:28:40 PM(UTC)
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 3/20/2019 7:54:34 AM(UTC)
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
