When You Hit Bake It Will Not Prset To 350 De. It Goes To 170 And Stays There But Broil Works Fine
That is a pretty good trick. More than likely it is a bad heating element.
This is the heating element I suspect is bad. This element is the most common replacement part for this particular stove: Jennair Schematic.doc (699kb) downloaded 672 time(s).SublimeMasterJW attached the following image(s):
