watstar
#1 Posted : Friday, May 14, 2010 5:00:22 PM(UTC)
watstar
I believe the dryer belt is broke on this dryer because the drum will not rotate , the power is on and their is heat but no spinning of drum.
sidfink43
#2 Posted : Saturday, May 15, 2010 4:58:26 PM(UTC)
sidfink43
This is kind of an older model, but I am kinda old myself so if I remember correctly you access this model by removing the two screws on the front at the bottom and swing the front out. You can also remove a service panel in the back. This will allow your to remove the top and replace the belt.
