casadevall2002
#1 Posted : Monday, May 10, 2010 1:03:45 PM(UTC)
casadevall2002
My ice maker voltage is reading 57 volts? I put tape on the flap that blocks the beam and on the light botton so I can see if it will run when it makes the beam.I tried braking the the beam while testing voltage and it never changed? Is there a fuse somewhere? Due to there being some voltage does that mean there is no fuse? I checked to see if it had a good neutral and it did. So now what do I try. Confused when I have some voltage but not the full 120v. I am an electrician so yes I had the meter set right.lol Just incase you where to ask.
FridgeDoctor
#2 Posted : Tuesday, May 11, 2010 1:44:50 PM(UTC)
FridgeDoctor
Groups: Expert
replace your emitter and receiver boards
casadevall2002
#3 Posted : Tuesday, May 11, 2010 1:58:57 PM(UTC)
casadevall2002
where is it located?
FridgeDoctor
#4 Posted : Tuesday, May 11, 2010 2:13:59 PM(UTC)
FridgeDoctor
Groups: Expert
in the walls on either side of the ice maker
casadevall2002
#5 Posted : Wednesday, May 19, 2010 1:06:02 PM(UTC)
casadevall2002
I put the new boards in it but it didnt work. Still reads 56 volts at ice maker. now what?
Guest (4)
