hmorton
#1 Posted : Tuesday, May 11, 2010 10:29:14 AM(UTC)
hmorton
If I run a small load, all is fine, however, My washer recently started to not finish in the last spin cycle leaving me with soaked clothes. It sounds like it's running, but the basket is not spinning. This morning we checked and the belt is fine. When the the spin cycle is on but the basket not tuning - we looked under the front panel and the motor and belt and such do not turn. However, if I take all the clothes out, reset it to spin only, I can get it to spin most times and throw the clothes in then and it will continue to spin as long as you don't let it stop! Need some serious suggestions on what to try next!!!
sidfink43
#2 Posted : Friday, May 14, 2010 5:48:31 AM(UTC)
sidfink43
This machine has a two speed clutchless motor, which may be the culprit.
Part number: AP3205861
Try replacing it. It is expensive but if you order from this site you may be able to return it if it does not fix the problem. See the returns policy before you order.
This is not a usual model, so let us know how it works out.
