Does anyone know how to remove a broken door stop from the refrigerastor door. I know it's the two screws, but I have know idea what kind of head is on the screw. it looks like an allen but it's move oval.
Groups: Expert
Originally Posted by: bdubs108  Does anyone know how to remove a broken door stop from the refrigerastor door. I know it's the two screws, but I have know idea what kind of head is on the screw. it looks like an allen but it's move oval. The best method for replacing the door stop on bottom of door: remove the upper hinger cover, remove the screws that hold the upper hinge to the frame, remove the upper hinge. Lift the door up and off of the lower door hinge, lay the door on its side on the floor. If you have wood floors, place something underneath the door to protect the floor. This will make seeing and unscrewing the normally 5/16" bolts, they may also be a 6 pointed torque bit headed bolt, though I cant tell you the size, that hold the door closer, the door stopper to the door frame.
Thanks for the help it's a T-20. just a cheap screw the aluminum was folded over most of the head.
