Margie B
#1 Posted: : 15 years ago
Margie B
Machine washes fine however,:confused: will not complete spin cycle at any speed. At the start of spin cycle clothing is gently tumbled in both directions 3 times. Afterwhich machine starts a sequence of beeps (two series of 3 beeps ea) then shuts off completely. As it is stops you can here the door lock release click. At this point the clothing is left soaking wet.
#2 Posted : 15 years ago
Perform the diagnostic test as described in the Tech sheet and post the results.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE ATF6000ES1 Frigidaire/washer | AppliancePartsPros.com
