hsjunya
#1 Posted : Monday, May 12, 2008 2:23:24 PM(UTC)
hsjunya
How to remove top of agitator (cloth mover) from bottom part....i need to install a agitator repair kit part # ap3094543
SublimeMasterJW
#2 Posted : Tuesday, May 13, 2008 6:20:35 AM(UTC)
SublimeMasterJW
Yank out the cup from the top.
get the bolt cover off next.
using a socket and extention remove the agitator bolt and washer.
remove agitator.
Place agitator on floor and hold base with feet.
Get all the worn out doggys out of the cam and replace them.
Line the top up with the bottom and snap the agitator back together.
re install the agitator. Easy fix. What can go wrong? If you are not careful you will break the tabs on the base that hold the top in place. Not good but not the end of the world. The agitator nut will hold it on in a pinch. Speaking of the agitator nut. Over tightening it will only cause misery,break the washer and generally make the agitator want to dance loosely in the tub. Not good.
SublimeMasterJW attached the following image(s):
hsjunya
#3 Posted : Tuesday, May 13, 2008 8:12:28 AM(UTC)
hsjunya
Thanks u saved me about $24 dallars and thats a good thing.
Removing Maytag agitator (Washer Repair)
by Guest 3/30/2024 5:55:35 PM(UTC)
Maytag topload agitator (Washer Repair)
by Guest 1/30/2024 7:23:54 AM(UTC)
GE top load with agitator - drum is free spinning (Washer Repair)
by JLS79 12/18/2023 8:21:30 AM(UTC)
Maytag Bravos Washer - Agitator spins fast/Drums spins slow (Washer Repair)
by JDugdale 8/29/2023 9:04:08 PM(UTC)
oil leaking under agitator into the washing drum (Washer Repair)
by sarte 8/1/2023 8:16:28 AM(UTC)
Beware when buying Agitator WPW1011020 (Washer Repair)
by Guest 7/18/2023 3:49:04 PM(UTC)
Should basket spin with lower agitator? (Washer Repair)
by bdollar 6/2/2023 4:44:56 PM(UTC)
Frigidaire Gallery Model GLWS1349AS0 Agitator Will Not Come Out (Washer Repair)
by Techowl 1/23/2023 10:39:56 AM(UTC)
My agitator bolt will not come out (Washer Repair)
by Guest 8/14/2022 4:47:19 PM(UTC)
GE Hydro Wave Quiet Agitator Wash System Lint Screen? (Washer Repair)
by Alphonse 3/13/2022 1:50:28 PM(UTC)
Whirlpool agitator&spin issues (Washer Repair)
by Guest 1/16/2022 10:55:31 AM(UTC)
Agitator barely moves (Washer Repair)
by Xicano69 10/25/2021 7:16:40 PM(UTC)
Grinding with working agitator. (Washer Repair)
by Guest 9/23/2021 1:10:18 PM(UTC)
Whirlpool washer agitator working but with grinding noise (Washer Repair)
by Guest 9/23/2021 1:06:39 PM(UTC)
Agitator Stuck! Can't get it out. (Washer Repair)
by TWash2 6/16/2021 3:22:28 PM(UTC)
