I shattered the window on the outside of my oven. I am curious as to how I can replace it for the cheapest cost. Do I have to replace the entire door? Can I just by the window? What sort of material is the window, plexyglass?? Again, I am looking for the CHEAPEST fix...
The oven is white and is a frigidaire...Model Number... 316244485... i think? i'm not sure
[COLOR="Blue"]Do I have to replace the entire door?[/COLOR] No [COLOR="Blue"] Can I just by the window?[/COLOR] Yes but it may be obsolete depending on the unit's age. [COLOR="Blue"] What sort of material is the window, plexyglass??[/COLOR] The window is tempered glass (safety glass) so the correct window must be used. Note that tempered glass cannot be cut or drilled so you cannot make one. [COLOR="Blue"]The oven is white and is a frigidaire...Model Number... 316244485... i think? i'm not sure[/COLOR] You need the model number. Model Number Locator |
THIS FORUM IS DEAD!!!!!!! |
