ccmjr77
#1 Posted : Saturday, May 10, 2008 6:38:46 PM(UTC)
ccmjr77
I have a Kenmore HE3T washer.
It has started making a loud rattling noise during the spin cycle.
It gets worse at higher RPM.
It sounds like something is between the inner and outer drum. I can not see anything. How can I check this?
Is this a bearing going bad?
Please help, the noise is driving me crazy.
thanks,
#2 Posted : Sunday, May 11, 2008 1:27:20 AM(UTC)
Rank:: Advanced Member
I would pull off the spin basket drive belt and turn the basket by hand to verify something in the tub. If so, I would remove the drain hose from the bottom of the tub and feel for something in there, if not, you might have a busted spider arm that supports the spin basket, eventually, this will punch a hole in the tub if not fixed.
ccmjr77
#3 Posted : Monday, May 12, 2008 6:45:01 AM(UTC)
ccmjr77
First of all, thank you for your response.
There is nothing in the outer drum that I can see or feel. I spin the drum manually and really do not here anything rattling around. Every now and then I can here something shift. It sounds like it is in the back of the outer drum. Is that were the spider arm is?
How do you get to it to replace and/or fix?
thanks.
#4 Posted : Monday, May 12, 2008 5:26:09 PM(UTC)
Unfortunately you have to remove the entire tub assembly to fix this. Usually if the bearings are bad, the motor overheats and will shut down.
Sorry, I have little to no experience with these washers.
You might want to post a new post and someone else will probably help. I do have a article about replacing Maytag Neptune bearings which would be similar to yours. The tub for your washer is probably around $400 plus shipping, not even counting the new spider assembly, so it's best to replace bearings. The article is under forum announcements.
Washer Noisy During Spin Cycle (Washer Repair)
by aedwards 4/22/2009 7:37:47 AM(UTC)
