#1 Posted : Sunday, May 9, 2010 10:34:52 AM(UTC)
Customer, a minister friend of mine, smelled gas and called me. Found a pressure regulator, part # 316091706 was leaking gas out the back and leaking a small amount of gas into the stove. Gas supplied with a propane tank.
Set oven to bake, igniter came on, but gas flow was too weak to allow ignition, a rather dangerous condition.
Columbia gas thinks this regulator has a built in safety valve. Is this true, or do I need to add a safety valve to the gas line. Thanks in advance.
Reviewing the safety valve info, it only closes when there is a much higher gas flow than would occur when everything is turned on, so it would have not done anything in this case.
#2 Posted : Friday, May 21, 2010 5:21:08 AM(UTC)
Update' replaced regulator, now all is ok. Far as I can tell, there is no safety valve in this regulator.
