The freezer is at -10F and holding but the Frig is above 55. I can hear fan blows but their is no air coming out that I can tell. I unplugged the power and let it sit with the doors open for 6 hours. After re-powering there was no change. The freezer stays at -10 and the frig is at 55. What are my next diagnostic steps. How hard is it for me to replace the parts myself. I do have ohm/volt meter and other tools.
There is a baffle that controls the air flow to the frig side of the refrigerator. it may say a-f or 1-5 if that baffle is not hook up it will be shut closed and you won't get any air. It is also good to check to see if there is obstruction such as ice or foam
THIS FORUM IS DEAD!!!!!!! |
How do you disassemble the unit to check this?
See page 2-11 in the manual |
