DaBull
#1 Posted : Sunday, May 11, 2008 7:04:02 PM(UTC)
DaBull
Hi, great site here where people can help each other out!
Have an issue where once you dispense the water into a cup and remove it, the water continues flowing for 2-4 seconds after removing glass from push switch. Never used to do this before, only started after I recently replaced filter. Tried removing line and blowing through it. Checked to see if filter was on correct. Any other suggestions? Thanks.
#2 Posted : Monday, May 12, 2008 4:12:01 PM(UTC)
You have to remove about 11/2 gallons of water after you replaced the water filter. Did you do it?
DaBull
#3 Posted : Monday, May 12, 2008 4:56:12 PM(UTC)
DaBull
How do you remove that water? Thank you for your reply! After I removed filter I tried pushing in push lever with cup, but only a few drips came out.
#4 Posted : Tuesday, May 13, 2008 11:36:32 AM(UTC)
The water dispensing system would not work without a water filter unless you installed the bypass plug instead.
You have to use the water dispenser to remove water from the system.
