Tsunamiron
#1 Posted : Friday, May 7, 2010 11:54:46 AM(UTC)
Tsunamiron
My upright freezer door won't seal or stay closed. It used to "suck closed" after I opened and closed the door, making reopening difficult. Then the drain froze up. I melted the ice from the drain with a hair dryer and some warm water. Ever since I thawed the drain the door will not stay fully closed. When the compressor and inside fan turn on, the door freely swings open about the thickness of a sheet of paper. The door seal lines up perfectly with the freezer doorway. If I don't lean something against the door all the time, my freezer will fill up with snow.
james orsak
#2 Posted : Sunday, November 21, 2010 9:39:49 AM(UTC)
james orsak
The same thing has been going on with mine. Have you come up with a solution? Is it as simple as replaceing the door gasket?
james orsak
#3 Posted : Sunday, November 21, 2010 9:56:06 AM(UTC)
james orsak
Also, My defrost tray is completely dry and my heating coil is extremely hot. Any assistance would be greatly appreciated.
