Jbud
#1 Posted : Sunday, May 11, 2008 11:04:25 AM(UTC)
Jbud
We have had problems with our Tappan oven during bake cycle since it nearly new. It beeps and displays an "F-1" error code and has to be reset. Sometimes it will complete the cycle and sometimes it will not. Sometimes it will not reset period. We delt with the problem for some time due to the cost of the part, (a timer unit) we were told was needed to repair it. Recently we replaced it and the part isn't a week old now and the problem has returned. (It did work correctly for several bake cycles prior to the "F 1" error code returning) Has anyone experienced this same problem? Can anyone tell me what is wrong or how to fix it? I've checked the internet for Tappan's web address to no avail. I assume they have been bought out by someone else?
#2 Posted : Sunday, May 11, 2008 3:58:47 PM(UTC)
There is nothing else which could cause the "F1" error code. Looks like the new part itself is defective. You have to call the place where you bought it from to exchange the clock under the part warranty.
