2 Pages<12
Tripehoundredux
#11 Posted : Friday, May 7, 2010 5:01:36 AM(UTC)
Tripehoundredux
Hello,
This would seem to be the best place to find an answer to this.
I need to replace the outer door of my spacemaker, I had a small flash over yesterday and, while the microwave works fine, the outerdoor has an area of warp from the brief flames. I see that the part can be ordered so that's good. However, looking at the microwave, I'm unsure as to how I remove the old outer door and replace it with the new part.
I assume that there are catches somewhere but I'm not sure where those are.
In searching for an answer to this I've noticed that many people are replacing the door handle so evidently that part is achievable (and in my case the handle is fine) but I'm not sure how I pry off the outer door after that.
Apparently the part will not come with instructions so hopefully somebody might be able to help.
#12 Posted : Friday, May 7, 2010 2:26:25 PM(UTC)
Very likely you have to remove the whole door from the microwave.
What is the complete model number of the microwave?
2 Pages<12
