Have a Frigidaire stove classic series that does not ignite on the burners, what troubleshooting should I be doing to figure out what part to replace, serial number is vf40444740 thanks for any help, thanks Paula
Hi Paula, If there is proper power to the range and there is no clicking sound when you turn on any burner then the problem is a bad spark module. - The part number for the spark module is AP2126193 Gene.
Thanks for your help Ive ordered the part and hopefully all will work well, thanks again Paula:)
