gcm
#1 Posted : Tuesday, April 27, 2010 4:25:45 AM(UTC)
gcm
I noticed oil on the floor under the washer and it appears to be coming from the gearbox where the motor shaft enters. I want to know if this can be replaced with a new seal or if the entire gearbox has to be replaced. It will go dry in time and lock up. gcm
Kanza
#2 Posted : Thursday, May 6, 2010 8:08:19 PM(UTC)
Kanza
replace transmission
