Len Kanter
#1 Posted : Thursday, April 22, 2010 1:29:13 PM(UTC)
Len Kanter
I am trying to find an ORIGINAL replacement 10 hr defrost timer for this model. So far, I've only been able to get an 8 hour one with a black wire pigtail coming out, which makes the installation iffy. I did install an aftermarket 8 hr timer, but my refrigerator/freezer is not operating properly (defrosts too often). The original part # is 2176648. It does not have any external wires other than the four copper clips coming out of the base.
#2 Posted : Thursday, April 22, 2010 4:19:58 PM(UTC)
Len,
The manufacturer had redesigned this part and the old timer is no longer available. According to the installation instructions, replacement timer will provide defrost every 8 hours of compressor run time.
Per the Tech sheet for this model there is Version 2 cumulative compressor run timer application and the timer should be wired as described in Procedure 3 (page 3).
- The defrost time authorized by Whirlpool Part number: AP3110896
webone
#3 Posted : Thursday, May 6, 2010 7:11:46 AM(UTC)
webone
I'm replacing the defrost timer - in the part instructions, it shows 3 possible situations and gives 3 possible schematics for the defrost heater circuit in order to know which pin to put the pigtail for the timer motor on. Unfortunately, I don't have the schematic for this refrigerator and I haven't had much luck finding one online. Can anyone tell me which pin it should be - or point me to a site where I can find the schematic?
#4 Posted : Thursday, May 6, 2010 1:17:16 PM(UTC)
