norm123
#1 Posted : Wednesday, May 5, 2010 12:03:44 PM(UTC)
norm123
:) I want to replace my white control panel and door panel with a black control panel and stainless steel door panel. :) Is it an easy DIY project and where can I get instructions?
#2 Posted : Wednesday, May 5, 2010 6:12:50 PM(UTC)
The black control panel Part number: AP4261639
The stainless steel outer door panel Part number: AP4323382
If you know how to handle a simple tools these parts are not too difficult to replace yourself.
Open the door and remove the six screws holding the control panel. Close the door and pull the top of the console away from the door. Disconnect the ribbon cable from the control board. Lift the console up to disengage the bottom tabs from the door frame and set the console aside. Remove the screws securing the control board to the console. Install the control board to the new console and assemble it in the reversed order.
Open the door and remove the four screws on each side of the door holding the outer door panel, securing the outer door panel with one hand from the front of it.
norm123
#3 Posted : Thursday, May 6, 2010 5:05:34 AM(UTC)
norm123
I'll try to take it apart and put it back together. If it works,I'll order the parts and do it for real. Thanks Gene.
norm123
#4 Posted : Thursday, May 6, 2010 5:11:21 AM(UTC)
norm123
Thanks Gene. I'll try and if successful, I'll order the parts and do it for real.
#5 Posted : Thursday, May 6, 2010 10:52:30 AM(UTC)
norm123
#6 Posted : Tuesday, May 25, 2010 9:24:07 AM(UTC)
norm123
Finally decided to try to remove panel but the screwheads are star shaped. What kind of screwdriver do you use for that?
#7 Posted : Tuesday, May 25, 2010 1:44:47 PM(UTC)
Sounds like a Torx head screws. You need a special screwdriver for such screws.
norm123
#8 Posted : Wednesday, May 26, 2010 5:37:46 AM(UTC)
norm123
Thanks. It's shaped like a star and went to Lowes. Didn't have the right size but now that I know its called Torx, I should have better luck.
norm123
#9 Posted : Tuesday, July 13, 2010 10:02:52 AM(UTC)
norm123
Gene,
Finally replaced the parts. Your advice was invaluable. Thanks again.
#10 Posted : Tuesday, July 13, 2010 7:28:05 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Guest (9)
