SheriO
#1 Posted : Wednesday, May 5, 2010 7:50:07 AM(UTC)
SheriO
Good Morning!
My microwave is not heating anymore. It appears to work normally, it just won't heat up.
And no, I didn't put a fork or any metal in there.
Thanks!
#2 Posted : Wednesday, May 5, 2010 3:01:23 PM(UTC)
This microwave made overseas and all technical information has been kept by Sears as a top secret. All parts are sold by Sears only as well.
tvtech
#3 Posted : Friday, May 14, 2010 11:11:42 AM(UTC)
tvtech
you can do some testing..
1. check 120 volt to primary
2. if ok check large cap and large diode
3. if ok replace magnetron.. (verify that you have 10 amp or so with clamp on amp meter to the magentron)
4 is 120 primary is missing look into control board area for loose connections. and such may need new control board
Guest (4)
Hotpoint/GE/Kenmore microwave blowing fuses (Microwave Repair)
by mje2019 10/21/2020 1:36:17 PM(UTC)
kenmore microwave (Microwave Repair)
by phi2cor 1/30/2014 5:24:34 PM(UTC)
Kenmore microwave 85470 (Microwave Repair)
by Binger 12/27/2012 7:17:48 PM(UTC)
Kenmore Microwave hood combination (Microwave Repair)
by curtisd 8/4/2012 1:21:52 PM(UTC)
Kenmore Microwave (Microwave Repair)
by jlezette 12/26/2011 1:43:32 PM(UTC)
kenmore microwave repair (Microwave Repair)
by ploou 11/3/2011 10:42:00 AM(UTC)
kenmore microwave, runs when plugged in, wont shut off (Microwave Repair)
by ice3x 6/27/2011 8:17:33 AM(UTC)
kenmore microwave has f2 error code (Washer Repair)
by bobval 4/29/2011 6:00:09 PM(UTC)
Kenmore microwave hood combo, no heat (Microwave Repair)
by billbr 9/28/2010 8:59:29 AM(UTC)
Replace Kenmore Microwave Door Latch (Microwave Repair)
by kwells 7/3/2010 2:57:56 PM(UTC)
'F3' display on the Kenmore microwave screen (Microwave Repair)
by jennifer555 3/25/2010 6:00:52 PM(UTC)
Kenmore Microwave no heat (Microwave Repair)
by desgross 11/11/2009 5:53:21 AM(UTC)
Kenmore microwave does not heat (Microwave Repair)
by srikki9 9/7/2009 11:15:49 AM(UTC)
Kenmore Microwave -No Heat, No Turntable -Related? (Microwave Repair)
by airheads 7/12/2009 12:40:12 PM(UTC)
Kenmore microwave no heat (Microwave Repair)
by nhdad17 6/6/2009 9:22:12 AM(UTC)
