cfilice
#1 Posted : Saturday, May 10, 2008 8:00:00 AM(UTC)
cfilice
Upper oven provides no heat from either the upper or lower heating element. Read out panel confirms operation mode in broil, bake or convection modes, but no heat at all. Fans and lights work fine. Lower oven works fine. Any ideas would be appreciated.
cfilice
#2 Posted : Saturday, May 10, 2008 2:25:22 PM(UTC)
cfilice
Thanks to gene of Mr Magic. Problem was a tripped hi heat switch, located behind upper oven latch. Reset switch and problem solved. Gene knows his stuff and is generous with his time. Am sending him a gratuity.
pasta
#3 Posted : Sunday, November 30, 2008 2:54:57 PM(UTC)
pasta
I had the same problem with the lower oven. I reset the switch,but it did not solve the problem. To reset the switch you just push in the red button, right?
Griffon
#4 Posted : Wednesday, December 3, 2008 9:24:11 PM(UTC)
Griffon
Thanks dudes. You solved my problem lickity split. Hi temp limit was tripped when I severly burned a beef roast. Reset it. Works great!!
bbaper
#5 Posted : Monday, October 19, 2009 9:56:37 AM(UTC)
bbaper
I took the panel off around the catch and found the red button on the right side. Worked like a charm. Dacor MORS130. All we did was the self cleaning. Service people must love this problem.
