tippywanknobi
#1 Posted : Tuesday, May 4, 2010 7:43:38 AM(UTC)
tippywanknobi
My 25 ft upright freezer ,freezes great but circulation fan in freezer will not cut off unless I rotate Thermostat . Thanks for any advice
#2 Posted : Tuesday, May 4, 2010 12:32:12 PM(UTC)
Originally Posted by: tippywanknobi Go to Quoted Post
...circulation fan in freezer will not cut off...
Does the compressor stop or it does the same thing?
What is the exact temperature inside?
What is the complete model number of the freezer?
tippywanknobi
#3 Posted : Tuesday, May 4, 2010 12:47:53 PM(UTC)
tippywanknobi
Gene my model # is EV200NXKQW. The compressor cycles and the freezer is frozen solid ( sorry i have no thermometer ), the fan will only turn off when I turn the dial inside to zero. thank you for your time.
Guest (4)
